Microphones
adcliqk
Microphones
Post by adcliqk »
Hello. i just bought a PDWM 9300, two wireless microphone system, and i want to use bothe microphones with Kjams. i know that 2 audio inputs is not supported right now. I downloaded the SoundFlower but i cant seem to make it work. can someone please give me some pointers on how to add this feature. maybe another program instead soundflower.
Thank You.
aantix
Re: Microphones
Post by aantix »
Just buy a mixer board. You don't need anything fancy; I bought this cheap one from RadioShack and it works just fine.
http://www.radioshack.com/product/index ... Id=2102920
Re: Microphones
you can use the "mixed" output to go directly into kjams
or get like a MOTU UltraLight and go into GarageBand
