bring back disable search as you type
I liked this setting. I don't care for it searching on every letter as I type it in.
Re: bring back disable search as you type
If you bring back the disable search as you type option I'd like you to keep the search as it is now as well, it's lots better because the I can leave the window and carry on with another job whilst the search is still going on in the background
i have to ask: what's the problem? it's not like kjams is wasting time or going slow or interrupting you, is it? is it just "a feeling thing" ? cuz technically, there is no problem that i can see. (or: is there some bug you haven't said?)
I just upgraded our karaoke laptop to an i7 2670QM Asus. Running Kjams on the previous Core Duo was brutal.
I just don't care for the the search as you type, the text field seems to lose focus/delay upon each subsequent character as you enter it. I've always just done partial string searches and was quite happy with that.
so, you're talking about a bug then. obviously, it should not be losing focus or delaying as you enter characters, that would be a stupid "design". can you provide some more details about how/when it loses focus? or what, exactly, the "delay" looks like? do you mean delay in the music? video? character entry? and, presuming these bugs are fixed, how exactly is it any different at all from having to hit enter at the end?
how many songs do you have? how much RAM? mac or windows?
Dave,
I couldn't quite put my finger on it. It just seemed "off". I've only had this on an i7 for a bit so not enough experience with it.
I think I know what it is. I can type about 90 words per minute. When I type in a song/artist kjams is missing keystrokes because I"m typing so fast. So, I might get the first letter into the text box and then 2 or 3 letters won't be caught as the search starts with each keystroke.
I find myself constantly backspacing the search box and forcing myself to type in slowly.
Okay, that's a bug. that's obviously not how it's supposed to work. kjams should never "miss" keystrokes, in fact, the way it's programmed, that's not actually possible. so now you've piqued my interest. can we get on the phone and do a screenshare so i can see this?
please call me during office hours:
Sorry Dave,
Almost no time (running a bar eats up alot of time... who knew). Try typing in something incorrectly and then quickly backspacing and typing it correctly
ah. so i tried this, typing really fast:
mac:
1) type some words, back space a bit (not to beginning), type some more
2) type some letters, backspace to the beginning (no letters showing), type some more
windows
3) type some words, back space a bit (not to beginning), type some more
4) type some letters, backspace to the beginning (no letters showing), type some more
and i discovered that 4) could miss a character that i typed. (1-3 all worked perfectly, nothing ever missed). the only reason 4 missed a character, is because on windows, adding tens of thousands of items to the data browser list ends up showing a progress bar! showing the progress bar brings a different window to the front, which then eats the key events. this is clearly a design flaw that i hadn't noticed before, thanks for bringing it to my attention.
presuming i fix this, would THAT float your boat?
mac:
windows
hah, you already floated it.
okay so i fixed it so NO DIALOG comes up when kJams is adding items to the browser, instead, it shows a task in the activity window. now, no characters are ever missed. that good?
