"Add to Library..." from kJams Music folder
Please exapand the "Add to Library..." function to allow you to add to the library any tune already in the kJams Music folder (such as when a tune is inadvertendly deleted out of the library).
MP3 import
I'll second that feature request, and I'll suggest that it's taken a little further. I'd like to make the process of adding mp3+cdg files as easy as ripping a CDG disk. That is to say, I specify a folder, and it would grab the files (maybe even zip them up!) and copy them into my library. Also, I'd like to be able to remove mp3 tracks in kJams and at least be given the option to delete the original file, allowing me to do all my library management from within the app.
This is pretty much how iTunes behaves, and I know you say "If iTunes has it...". Hope to see this in the future.
okay
As you can see here under "What My Plan Is", line number 14 i have:it would grab the files (maybe even zip them up!) and copy them into my library
that's been my plan all along. (I just added "zipped")option to copy or reference files when "Add to Library…"
Already there: "Edit->Trash Original Files..."be given the option to delete the original file
Sounds good
Thanks! How about adding the option to delete the original file to the "Do you really want to remove this from your playlist?" dialog box? Or even better, how about a key combination to trash original files? (or is that too dangerous?)
No, they really are separate commands, they should remain separate, to force the user to invoke the command they really mean.How about adding the option to delete the original file to the "Do you really want to remove this from your playlist?"
It's such a rare thing it doesn't really warrant a keyboard shortuct. However you can add your own:about a key combination to trash original files?
Customized Keyboard Shortucts
clarification
I was using the Delete button on the keyboard, not the menu items. I agree that they should remain separate menu items. Personally, I prefer using the delete button to get rid of files and when I press delete I would have liked to be given the option to delete the original file, like in iTunes.
You can easily set "Trash Original Files" to use the Delete Key for a keyboard shortcut
pretty please?
The keyboard shortcuts are very handy and flexible for sure, but I move my kJams database around to different computers often and I'll have to remember to bring the Keyboard.txt file over. Any chance we might see a legit keyboard shortcut in the app at some point (I'm asking because I'm lazy, in case you didn't get that)? Maybe something like this:
Delete = Remove from library
Command-Delete = Remove from library (don't warn)
Shift-Delete = Trash file
Command-Shift-Delete = Trash file (don't warn)
okay i'll add it to the list
