I/O error (bummers)
Bmurray
I/O error (bummers)
Post by Bmurray »
Howdy Dave,
I added several songs to my library that were referenced to a drive in another mac on my network.
The songs will load and play great =-) However, when I try to [Reinterpret names] I get the following error.
-- There was an error saving the file "MY_EXTERNAL_DRIVE": "ioErr, I/O error (bummers)"
Then the library shows the selected songs as if the [Reinterpret names] command worked. However, the next time kjams Pro launches the original data shows in the Library.
please advise.
Thanks,
Banister
Re: I/O error (bummers)
well, you need write permissions.
is the remote volume formatted HFS+?
is it shared via AFP?
generally i recommend AGAINST doing meta data editing over a network, you should do them locally.
Bmurray
Post by Bmurray »
The remote volume is - Mac OS Extended (Journaled)
I have granted read/write access to "everyone" on that drive.
Still no joy
missed one very important question
Bmurray
Post by Bmurray »
Oh yea, confirmed, I am using AFP to connect.
I was able to install kJams on the other computer, make all my meta data changes, and then delete and re-import all the referenced songs on the main computer. (The Pull meta-data feature, didn't work for me, had to delete and re-import.)
After going thru this experience, I can see why you would recommend against doing metadata edits over a network. :wink:
As a 'nice to have' feature, I think it would be cool if kJams could detect when a song is referenced and not local, and then disable all the meta-data edit features. :D
huh. the thing is it *should* work. could be a glitchy router?
anyway, glad it's all working now.
