I Love KJAMS! Dave is the best. I have this problem.
SwampTrax
Post by SwampTrax »
Auto update failed, went to website and downloaded and tried to copy it to applications folder. I think I screwed up!
Process: kJams Pro [13371]
Path: /Applications/kJams Pro.app/Contents/MacOS/kJams Pro
Identifier: com.metamuse.kjams
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [122]
Date/Time: 2012-08-30 20:26:56.111 -0400
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 61677 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 17C76661-C006-40A0-88BA-B8CF89FE8CBF
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: @loader_path/../SharedSupport/libboost_thread.dylib
Referenced from: /Applications/kJams Pro.app/Contents/MacOS/kJams Pro
Reason: image not found
Re: I Love KJAMS! Dave is the best. I have this problem.
hmm, it's working for me. send me an email and we'll try to figure it out.
SwampTrax
Post by SwampTrax »
I deleted it and re-downloaded it from the web site again. It ran this time. Then it auto updated. Then I downloaded and installed the producer plug. It crashed the first time I ran it. Then I dropped a file made with ikaraoke Tuneprompter and it opened it and played it fine. But complained about a timing conflict. I was then able to get into producer and see all the timeline stuff and watched it play through to the end. Maybe I'll learn to use it. I have been wanting to make my own karaoke files for years. Thanks for a great program. If I can get comfortable with producer, it will be even better.
WHAT crashed? kJams crashed? or kJams opened fine but crashed when you called up the Producer plugin?
send me the KTP file and the audio file, via email, thanks.
010hnoor
Post by 010hnoor »
NOOR
i still need you to send me the KTP file please. that's how i can help.
okay good, but just to be sure, what version of kJams are you on now?
that's strange because there IS NO producer PLUGIN any more, it's built in. so can i ask, where did you even FIND a Producer Plugin to download? is there a link somewhere?
please be more specific. did kJams crash on startup? or did kJams start just fine, but then when you went to open Producer it crashed? HOW did you open producer? please tell me every single step you took.
do you mean you drag-and-dropped a KTP file into kJams?
and it opened
do you mean "kJams loaded the KTP file and showed it in my library like any other song"?
and played it fine
i assume you mean either it auto played or that you double clicked on it to play it.
so then what happens if you stop the song, then pick Producer? does it crash?
again: send me the KTP file (and the audio file)
