Quick Search
waynegfx
Quick Search
Post by waynegfx »
I have tried and tried to get Quick Search to work on my Mac. I type the first letters and nothing comes up. I have to type the whole name or sentences and press enter to get search to work. Is there something I am not doing....it is really slow searching my library. Thanks so much for any help
Re: Quick Search
sorry, what do you mean by "Quick Search"? do you mean "Targeted Searches" ?
do you have the activity window showing and NOT overlapped by any other window?
waynegfx
Re: Quick Search
Post by waynegfx »
Anticipated Search, like when a singer turns in a request and I look on the Kjams Library for the song. I thought it would start searching for the song as I type letters on the keyboard, it does not do that, I have to type the entire song title and hit return for it to look up the song.
Re: Quick Search
also, there is nothing called "anticipated search". perhaps you mean "update search results as you type", which is built in and working. what version of kJams are you using? the older versions did NOT have USRAYT. also, you did not reply to my Q about the activity window.
waynegfx
Re: Quick Search
Post by waynegfx »
I'm sorry Dave, the activity window is behind the main library window. KJams updates often so I'm sure
I have the latest version. Thank you for
Answering all these questions.
Re: Quick Search
you should arrange your windows so that the Activity window is NOT overlapped by the main window.
please confirm the version number, what is it exactly? thanks!
waynegfx
Re: Quick Search
Post by waynegfx »
Dave I am on version 1.0b10 and I tried to have the activity window not blocked and the search took 8 seconds,,,,when I type Artist:(singer name) and return it is 3 seconds....but nothing when I type say....A for Ace of Base like as I type more letters nothing until I type all the letters and enter. thanks Wayne
Re: Quick Search
i think i fixed it !!! Please try the rogue
waynegfx
Re: Quick Search
Post by waynegfx »
Dave, do you mean get rid of kJams Pro and download the rogue? I was a little nervous to do that...I'm sorry I am so confused about all of this, thank you so much, Wayne
waynegfx
Re: Quick Search
Post by waynegfx »
Dave, Sorry, I read the instructions and followed it, and it works so much better now, THANK YOU SO MUCH, YOU are a Karaoke GOD
Re: Quick Search
