Time Last sung
Time Last sung
One of the previous kJams had in the column called Date the both the time and the date the singer last sung. Now it only has the date and no time.
Will this stay like this or will we be getting the time info back. I used that info when a singer complained that they'd not sung for hours and I could show them they were dreaming
Re: Time Last sung
Re: Time Last sung
Yep, but the Date column only shows the date and not the time a song was done. It used to only show the date when someone hadn't sung that night but once they'd sung it used to show the time as well
Re: Time Last sung
Sorry, i guess i misunderstood! okay, drag the width of the column to be wider, you'll see the time too
Re: Time Last sung
Ah I see, I did try to drag the column wider but it would only go wide enough for the date
Re: Time Last sung
what is your "Browser font size" in advanced prefs?
Re: Time Last sung
I've just changed it to 13 n it's now OK but if I have it set at 14 I lose the Time.
Never thought of that!
Is there any chance of allowing more space for the column
Re: Time Last sung
yep, it'll allow you to make it bigger in the next release!
