Library sort order
MichellePar
Library sort order
Post by MichellePar »
When I'm working on my database, I like to set the sort to album for the library. I'd like to make the secondary sort then by track order within the album. I can't get it to happen that way, and I'm not sure what I'm doing wrong. Any advice?
Re: Library sort order
currently not possible with the kjams UI.
but it will come eventually after i get "Fast Search" done.
if it's super duper life saving critical for your work, let me know and i may be able to give you a special hack.
MichellePar
Thanks for the rapid response. It isn't critical, by any means, I just like to have things organized in order. :D
